4430 quad problems
chris meredith
10-26-2005 20:01:08
we have been working on 4430 we put a rebuilt quad tranmission in it when we got it back to gether it would not shift form 1 to 2 or 3 to 4 or eather one of the reverse i will pull ok but i just want shif tdoes any one have any ideals on wht to do next thanks for any help
michael
11-12-2005 15:40:58
 Re: 4430 quad problems in reply to chris meredith , 10-26-2005 20:01:08
i have a suggestion get a 4020. never had any problems with mine.
michael
11-12-2005 15:40:57
michael
11-12-2005 15:40:55
michael
11-12-2005 15:40:57
michael
11-12-2005 15:40:51
donmyeil
10-28-2005 06:30:00
sounds like the shifter fork for the two speed is out of place. cant shift if the valve cant move up and down. just a thought
lonzo
10-27-2005 04:12:37
have you checked the linkage under the cab? engin dead, shift the lever and see if there is a deffant click from one shift to the other. if there is then remove the clutch valve houseing and use air pressure to test clutch packs and see if there working, You have a 10 cent item causeing your trouble, let us know what you find
