'50 B governer/magneto problem
Johnlobb
10-26-2005 16:07:00
Well, I am beginning to feel this is the tractor from HELL! I put the head back on after having it milled and no water leaks! Rah! Went to start it and no fire. Found the magneto nut on the lugs loose, took it back to the guy that rebuilt it, He said this had never happened to him before, he fixed it, I took it home, reinstalled it and now the lugs do not engage into the slot in the governer. Somehow the slot in the governer has moved back from the face of the magneto. The guy I bought it from had the end plate (flywheel side) off the governer and replaced a broken part and installed a new end bearing. I have seen a couple of places that have warned not to remove this governer cover plate. Is there some way to get the slotted end to go toward the magneto so they will mesh again? Thanks again for all your help in the past. John
DickD
10-29-2005 07:50:09
 Re: '50 B governer/magneto problem in reply to Johnlobb, 10-26-2005 16:07:00
John; We worked on the governor of a B one time and if memory serves me, which it doesn't most of the time anymore, I think your problem stems from the shaft not being installed properly from the flywheel side. We had this same problem. Sorry I can't be of more help, but maybe this will get you on the right track.
Mike M
10-27-2005 05:26:48
I'd say that since you know they were in the gov. area "fixing" start looking there something may not be put together right.
greenmech
10-26-2005 19:48:09
Could be your mag shaft got pushed back when the governor was fixed? I would try another mag first then if that doesn't work you may have to look at the governor shaft. Ron Mn.
Johnlobb
10-27-2005 02:47:38
 Re: '50 B governer/magneto problem in reply to greenmech, 10-26-2005 19:48:09
I measured my mag"s length from where it sits on the governer to the end of the (short) lugs and that is 7/8". When I talked to the guy that did my mag, he checked one of his new Wico X mags and said the measurement matched mine. John
