4430 Motor
Chuck McDonald
10-26-2005 12:25:29
I have a buddy whose 4430 motor blew up. He would like to replace it and was looking for a good used motor source or a good remanufactured engine source.
Also, what motor model is in the 4430?
Thanks
Chuck
MSM
10-26-2005 13:59:12
 Re: 4430 Motor in reply to Chuck McDonald, 10-26-2005 12:25:29
The tractor uses a turbocharged 404. If his engine hasn't tossed a rod through the side of it,or broken or severely damaged the crank,it might pay to do an out of frame overhaul.A reman engine is going to be in the $8000+ range with the incidentals and labor to install it,assuming the core is good. A decent takeout from a salvage yard is probably going to run $3000+/-, plus labor,possibly more if it is a combine engine and you have to change over manifolds,oil pan,water pump,etc. No matter which route he takes it isn't going to be cheap
