F-I-T, News about the R gauge panel
parrothead
10-26-2005 06:19:28
Just for reference purposes, that #13 bolt in the diagram that you posted is actually a long square head bolt that runs from inside the fender all the way through to the dash. There is one on each side and they were tough little boogers to remove. Now it looks like I'll have to remove the line from the oil pressure gauge. There is absolutely no room to work with as far as the gauge line goes. I'm hoping that I can squeeze a wrench in there. All this just to get the light switch to work!
Magoo1
10-27-2005 11:07:13
 Liveoak Farm Days?-Nov. 5th in reply to parrothead, 10-26-2005 06:19:28
Can you tell us anything about the Event in Live Oak next week in?
Thanks
Magoo
F-I-T
10-26-2005 13:26:37
 Re: F-I-T, News about the R gauge panel in reply to parrothead, 10-26-2005 06:19:28
PH:
Glad you are getting it figured out.
Like Bob said, sometimes you can get the oil line free from the far end and bring it out together.
Wish I had some advice for you, but at this point, all I can offer is best wishes!
Frank
Bob
10-26-2005 07:33:40
Can you disconnect the LOWER end of the oil gauge line from the block, and then pull the gauge panel back a bit, to get access to the upper fitting?
parrothead
10-26-2005 08:24:43
 Re: F-I-T, News about the R gauge panel in reply to Bob, 10-26-2005 07:33:40
I think I'll try that. There is also a clamp under the hood that holds the line and some wires. The line is really tight there so I'll loosen the clamp and see how much room that will give me after I remove the line from the engine. Hopefully I'll get a chance to do it tonight.
