800 series 3-pt hitch
DeltaFarmerClint
10-25-2005 20:18:52
Does anyone have a diagram of these hitches. Did John Deere have a factory center link for tractors such as my 50, if they did where does it connect on the tractor. I am trying to find all of these parts and I want to make sure I dont skip over any pieces I need.
buickanddeere
10-27-2005 06:50:34
 Re: 800 series 3-pt hitch in reply to DeltaFarmerClint, 10-25-2005 20:18:52
If in a pinch. Hoxey Hitch in Michigan make a very beefy bracket to mount the upper third link too.
Wes Miller
10-26-2005 18:24:19
I have the owners manual for the 800 3-pt hitch if you are interested. It is in good shape for its age. All pages present and with only some greese marks.
JDVan
10-26-2005 00:20:35
I have an extensive amount of information on 800 series hitches at:
Link
Able
10-26-2005 03:32:16
 Re: 800 series 3-pt hitch in reply to JDVan, 10-26-2005 00:20:35
jd van, is the bottom lift arms on the 800 or 801 hitch telescoping, you know you pull a pin to make them extend, makes hitching up to implement much easier.
JDVan
10-26-2005 07:15:55
 Re: 800 series 3-pt hitch in reply to Able, 10-26-2005 03:32:16
Yes, The bottom two draft arms on the 800, 800A and 801 versions of the 800 Series hitches do have the telescoping feature. If they are not rusted stuck! A very handy capability and I beleive JD was the first to offer that capability.
Able
10-26-2005 10:37:42
 Re: 800 series 3-pt hitch in reply to JDVan, 10-26-2005 07:15:55
thanks
D cotton
10-26-2005 19:04:15
 Re: 800 series 3-pt hitch in reply to Able, 10-26-2005 10:37:42
I had a set of arms that was frozen up due to rust.. I took it and made a nice hot oak fire that i fed for about 4 hours to cook it.. When it was done i was able to pull them apart rather easy.. Before i had hooked it to a tree and dang near killed myself trying to pull it apart...
Just a FYI..
