Gresen Valve Sticking
Larry Zamzow
10-25-2005 09:03:58
I posted this question the other day. However with the responses and learning a little more I can maybe state my question a little better in hopes I can get this problem resolved.
I mounted a 48 loader on a 4010. I installed a "power beyond" kit and a Gresen valve (2 spool double action; closed center. The valve was new out of the box and had never been used. After mounting, etc., I connected the hoses to the valve. On one of the valve (the short side) I have good up and down action; the valve is centered. However, on the other side (the long side), the valve is out more than 3/4 of the way, and will only work good in one direction (pushing the lever forward). If you pull back, the cylinder reacts very slowly, because there is very little movement in the valve (i.e. it is not centered). If you shove the valve all of the way in, it sticks. On the front end of this valve, there is a rubber cup which protects some sort of bolt looking cap (shiny). On the other side (short) there is no such thing). Is this cap something you can turn on for adjustment? Can anybody figure out what my problem is? When I received the valve all of the plugs were in and no debris should be in there. One person that rread my prior post suggensted I rotate the valve 180 degrees. I tried that; but it did not go in.
Thanks in advance to anyone who can help.
P.S. I called a guy at Baum Hydraulics; who again was speaking over my head. He started referring to a "detented tension adjustment" or something like that. I gave up on that conversation and punted. So here I am again asking for help. Seems like I get problems fixed everytime I post a question here.
matthies
10-27-2005 20:52:41
 Re: Gresen Valve Sticking in reply to Larry Zamzow, 10-25-2005 09:03:58
I looked through my Baum book and found a valve you described. Try operating the short spool while the long spool is either raising or lowering. The book says that the long spool feeds the short spool during operation. chris
MSM
10-25-2005 13:19:21
Your raise/lower function should be plumbed to the "long" side of the valve. This spool has a "float" detent,which will alow the bucket/loader to float when pushed all the way foward. The bucket curl should be plumbed to the other spool.
How did you plumb your "power beyond"? Deere never offered a power beyond kit for the 4010.If incorrectly plumbed,your feed/return could be causing the problem you are encountering.
Larry Zamzow
10-25-2005 13:30:56
 Re: Gresen Valve Sticking in reply to MSM, 10-25-2005 13:19:21
Yes, I've already learned today I should have the loader raise/lower plugged into the "long" side of the valve. I also now understand what a "detent" is, or rather what it is for. The "power beyond" stuff wasn't in a kit, but rather bought in basically two pieces from the John Deere place. They told me what I needed to do. It included an expanded hydraulic filter housing with a threaded hole for a return line, and a "T" fitting to fit in place of the "90" that goes where the hydraulic line comes out of the tractor near the brake pedals. I ran the hoses from the valve via inlet/outlet respectively. I'll double check. I think I understand how to operate the valve now.
lonzo
10-27-2005 04:24:34
 Re: Gresen Valve Sticking in reply to Larry Zamzow, 10-25-2005 13:30:56
Have you tryed looseing all 4 mounting bolts and see if maybe the houseing was in a bind the mounting bolts were tight ?
Mike M
10-25-2005 09:23:45
Most loader valves will have a detent on one valve. You use this one on the lift cylinders and when hooked up right with the loader all the way down you can push the lever into this detent position which allows it to float. I mainly use this when backdraging. Your valve may not be what was suppose to be in the box or it could always be defective ?
