70 D question
Dan
10-26-2003 12:57:29
I,m in the process of restoring my 70 D and I would like to know if the floatride seat it has on it is standard equipment. I can not find it in the parts manual and a couple other things like the air stack are original for the 720.
Clooney
10-26-2003 15:40:00
 Re: 70 D question in reply to Dan, 10-26-2003 12:57:29
Dan, as Frank said the float ride seat came later. You will find the float ride seat won't allow your seat box tool box door to work properly. About the time the float ride seat came out that tool box door was eliminated...
F-I-T
10-26-2003 13:29:47
Dan:
The Float-Ride was not available from the factory for the '70'D, but as soon as it became available for the -20 series, it was offered through dealers as a retrofit kit. Dealer accessory catalog AC-1000 shows the kit available with either Black or Yellow seat cushion.
There was an air stack available for the 70D, and it differed from the 720 style stack in that it exited through the top tin of the nose cone, while the 720 stack exited straight up from the aircleaner, and through the tin of the hood, straight across from the muffler mounting flange.
Frank
