Hyd. Oil Temp/MSB
Pete/ME
10-25-2005 02:33:07
A page back, answering a hyd. oil temp. question, (by the way I think I've seen in-line oil temp gauges in the "Northern" catalogue)MSB said "the use of a hydraulic motor driven by a closed center pump will give an unsatisfactory performance unless used for very short periods of time." Does this mean that I can't use my Valby CH150/power feed on my 2240 or 4020? (Both closed center) I've replaced the valve with a C.C. and re-plumbed according to instructions from the U.S. distributor.
msb
10-25-2005 08:00:37
 Re: Hyd. Oil Temp/MSB in reply to Pete/ME, 10-25-2005 02:33:07
No, It doesn't mean you can't use it.It means you will probably get some chatter in the motor.I have run a hydraulic motor on a truck auger for years now and it chatters,sometimes breaking the bolts in the auger screw.I just live with it.And the oil will get hot if run long enough,but it usually only takes about 20 minutes to unload the semi,so it really isn't a problem.
Pete/ME
10-26-2005 02:32:11
 Re: Hyd. Oil Temp/MSB in reply to msb, 10-25-2005 08:00:37
Thanks, msb. Is the chatter from cavitation?
Pete/ME
10-25-2005 02:39:59
Oh yeah, and I T-d into the feed in front of the brake pedal and am dumping into the filter cover. made up separate remotes/quick couplers.
