2030 hyd. problems
davids
10-24-2005 21:02:57
If I have a roll of hay on the 3-pt. lift and try to use the front end loader, the lift will fall to the ground but when you release the frontend loader control handle, the lift will come back up to the level it was. Full of fluid and the filter was changed yesterday and found no trash in it. Any ideas are greatly appreicated. Thanks, davids
msb
10-25-2005 08:02:46
 Re: 2030 hyd. problems in reply to davids, 10-24-2005 21:02:57
Set your L&D in the depth position.That should take care of the problem.
Tx Jim
10-25-2005 03:51:19
David,your rockshaft control valves or piston o-ring must be leaking. How long will rockshaft stay up when engine is stopped? Does oil get hot? Look in hyd. filler with 3 pt.raised and engine running for spraying oil. Tx Jim
