41 war time A
Don in the Nort
10-24-2005 12:29:03
I am considering buying a tractor out of the weeds which is supposed to be a "war time" A. I was told that the big difference was the steering wheel had a soybean type additive to replace the rubber and the frame was made of cast. Does this sound right to you more experienced guys? If this is accurate, does this affect the value of the tractor any? I sure appreciate your insight! Happy wrenching!!
Jim@concordfarms.
10-25-2005 14:28:55
 Re: 41 war time A in reply to Don in the Northwoods, 10-24-2005 12:29:03
Have a '44 A bought new by my grandpa. Cast frame, pressed steel wheels, hand start, powr-trol, 6 speed, PTO, copper radiator. Ser. no. 538915. Still running strong. Jim.
Steve Crum
10-24-2005 21:46:47
I have a 44 A I bought from the original owner. Very basic. Cast frame, hand start, pressed wheels, no electrics, COPPER radiator and 6 speed with PTO. Dad said this was about all you could get during the war. The steel cores and pressure cooled systems he said came in the early 50s due to copper shortages during the Korean war. Steering wheel is rubber coated. 2 grand it's yours!
Will P
10-24-2005 20:55:20
War time, well, All of the 41 and 42 tractors had angle iron frames. The first half of 43 had angle iron frames. The second half has cast iron frames. All of 44 had cast iron frames too. The end of 42, all of 43 and 44, had steel serial number plates, and allot are rusted and you can"t read the numbers. The first half of 43 had non-pressure radiator caps. The first 1000 tractors with the cast iron frames had non-pressure radiators. Then Deere went to pressure radiators with a steel core for the rest of 43 and all of 44. Have I got you lost yet? So, find out what you are looking at and I can help you.
I have heard that of the steering wheel. Also, war tractors turn turquoise because lack of good pigment used during the war.
Will P
43 A, angle iron frame
43 B, cast frame
49 G
51 G
GTX1967JEWISON
10-24-2005 21:17:06
 Re: 41 war time A in reply to Will P, 10-24-2005 20:55:20
well I have a 45 a with ORIGINAL angle iron fram, not cast. original serial # also. what now? also the radiator is non-pressure type. it is a non-molested 45. also in norther nd where i grew up I ran one identical to it & it too was a 45, original owner, never apart. ran it for several years, 12hrs/day all summer picking rocks & haying.
Will P
10-25-2005 04:21:23
 Re: 41 war time A in reply to GTX1967JEWISON, 10-24-2005 21:17:06
And your point is what? 1945 they went back to angle iron frame and non pressure cooling. I never said a word about 1945. So don't jump all over my a$$.
Will P
960
10-24-2005 13:04:51
The frame is different in shape and it is cast. The steering wheel I have never heard that. Value-my 43 is for sale and in pretty decent shape having had engine work and paint in the last 7 years and no one has any interest priced in the mid teens.
Dup43
10-24-2005 16:32:54
 Re: 41 war time A in reply to 960, 10-24-2005 13:04:51
They also had steel radiators due to the shortage of copper during the war.
10-25-2005 07:57:05
 THANK YOU ALL! in reply to Dup43, 10-24-2005 16:32:54
Hey THANK YOU all for the information! WOW is there tons to learn!! :-)
Happy Wrenching!!!
