630 shifting problem
tractormanq
10-24-2005 05:25:20
Have a JD 630, gears on left side of shift pattern will not work unless i go to right side of quadrant, engage a gear ,and then come back into a left side position. Even then sometimes i have nobody home on left , and i have to go back to right side again, and hope it works. sometimes i have to do this several times. Any one out there have any ideas what i may be looking at for repairs? Its a 630 Row Crop.
BushogPapa
10-24-2005 06:11:16
 Re: 630 shifting problem in reply to tractormanq, 10-24-2005 05:25:20
It could be a worn shifter lever (at the bottom) or a bent or worn shift fork... Could be worn detents with broken springs... Is the shift-lever loose at the ball where it goes through the top of the transmission..?? This is pretty common.. Those bolts can only be tightened when the steering tower and shift quadrant are removed... Then, it could be a combination of wear and clearances stacking up..probably the least likely, tho...
Ron..
