Gressen Valve
L. Zamzow
10-23-2005 17:04:02
I bought a loader for my 4010 and subsdequently a dual spool valve "gressen" or John Deere. It was brand new out of the box from someone who had ot in their garage 30 years or so. I got eveything mounted & hooke up; but one lever works up and down good, but the other doesn't. It has a catch in it and will only go one way. If you go all the way in that direction; then if you push the lever in the same direction, it will kind of go down. I wonder is something stuck in that valve & how hard will it be to correct?
Like I said, it was brand new.
Thanks
Roy Suomi
10-23-2005 19:26:46
 Re: Gressen Valve in reply to L. Zamzow, 10-23-2005 17:04:02
Try turning the valve spool 180 degrees, then install linkages back up. If that doesn't do it, you might have a slightly bent valve spool..
matthies
10-23-2005 17:27:06
On the side opposite the handles, are there rubber covers. Any way under the covers/end of the spool, see if there is a snapring and washer/flat plate. Had a friend with a gresen valve on a loader and the snapring and plate were gone and caused a problem like you mentioned. It should look the same on the end of both valves. chris
