right side cover reduction gear bearing
Ken Tabor
10-23-2005 14:19:33
I have a 46 model B. Had a problem in past with severe wear on the top transmission shaft inside the case. Replaced this with a good shaft and new bearing in the case. In putting the new bearing in the side cover that supports the end of the first reduction gear, the bearing is not tight in the case housing. Has about a 32nd of an inch slop on the outside of the bearing to the case. Is this the way it is supposed to be. It is the same way the old bearing that I removed was and I cross checked the bearing numbers and it is correct. Ken
Mike M
10-23-2005 17:48:20
 Re: right side cover reduction gear bearing in reply to Ken Tabor, 10-23-2005 14:19:33
Any machine shop should be able to fix that housing. You should have an unworn spot past the snap ring to use for measurement.
RalphinWI
10-23-2005 15:21:10
The case housing is worn. In an A that I recently had apart, the bearing had gone to pot, the splines on the first reduction gear were almost completely rounded off and the case worn. Fortunately my chief consultant/mechanic had the reaming kit and one(1) shim left for an A. A few old time mechanics or some dealers will have the kit and required shim.
