Engine noise
MATT VR
10-23-2005 09:49:14
On my 48 B i just am finishing up i hear this slight nocking/slaping noise, it does it at any RPM, but say i was to drop or raise the RPM's, during the time of change the noise stops until the RPM speed has leveled out then it returns, the noise doesn't vary with the clutch being engaged or disengaged, my thinking is that the rod bolts have to be tightened up a little, could anyone tell me if my hunch is right, or where else to look, thanks
MATT
MATT VR
10-23-2005 18:43:04
 Re: Engine noise in reply to MATT VR, 10-23-2005 09:49:14
I hope both of you are correct, one more piece of info that might help is that when standing right next to the tractor it isn't that loud or noticable, but when you squat down and listen by the petcocks/starter is is louder. Would it still be that piston skirt slapping?
thanks again for help
MATT
Will P
10-23-2005 20:07:01
 Re: Engine noise in reply to MATT VR, 10-23-2005 18:43:04
I had the same thing with a G that I got up and running. Sounded fine but you speed it up or slow it down, you heard a knock. The wrist pin bushings were spinning in the rod. Open up the crank case and pull one of the pistons all the way back. Rock the cranks forwards and back and see if the rod moves forward and back and the piston don't. I hope for the best for you.
Will P
MATT VR
10-24-2005 16:12:01
 Re: Engine noise reply to will P in reply to Will P, 10-23-2005 20:07:01
Mine only does it when it is at a stable RPM when the engine speed is changing you can't hear it, and i think before i put the pistons back in they felt tight where the rod meets the head. I'll still take the crank cover off and take a look
thanks MATT
Bushogpapa
10-23-2005 18:04:47
My '52 "B"has had that noise for at Least 40 years, and it has never gotten any worse.... I even pulled the pistons once and everything checked out.. It must be piston skirt slap.... Don't mess with it unless it gets a bunch worse....!!!!
Ron..
lonzo
10-23-2005 16:04:34
my 520 makes the same noise, it't the piston skirt slaping the side of the bore, i don't pay any never mind to it , the rod bolts won't make any noise, it's the loose bearings if the bolts are tight,
