720 LP Tranny problem
Haskell Haymake
10-22-2005 20:55:51
I have a 720 row crop I bought in april. Tractor originally was a cotton tractor in west Texas. Any way the axle seals were leaking because tranny and first reduction case were full of Milk of Magnesia. I drained almost 20 gallons out. After flushing and filling the case with oil and the first reduction case I took it on a road test. Coasting down hill as it gains speed I here a whackin in the tranny floorboard area. As the summer has gone on I have used it quite a bit probably 50 hours or so mowing hay. 1-5 are quiet, but can on use 6 at slow engine speed and only under a load. I can go to the field in 6 with a slight whack, give it the throttle and it gets more frequent and louder. Most prevalent coasting down a hill under no load. You can make it better by riding the brakes, if you don't sounds like a gear is fixing to make a new inspectin hole! Thanks for your help in advance.
BushogPapa
10-22-2005 21:02:53
 Re: 720 LP Tranny problem in reply to Haskell Haymaker, 10-22-2005 20:55:51
Sounds like a chipped or broken gear tooth...
At least 4 and 6 are outside the case and easy to get to...!! Ron..
