JD R won't prime
kp
11-07-1999 18:44:27
I've just overhauled a 1951 R & cant get any fuel to the injectors. I bet it is something simple but I've tried everything. Any suggestions would be great. Thanks KP
Mike H
11-07-1999 21:10:51
 Re: JD R won't prime in reply to kp, 11-07-1999 18:44:27
The two cyl.diesels are hard to prime because the pumps are higher than the injectors but on my R i found that by removing the pump cover for the bridge on which the pumps mount on each side there is a 1/8 plug, crank the engine over and remove one plug at a time to remove air and of course put back in then loosen the injector line at the injector and bleed the air then tighten it should start. the air forms a bubble in the bridge that won't budge
