4010 brake valve question
PUTTER
10-21-2005 07:32:29
I just got my parts to repair my brake valve, wow lots of little O rings. Is there any place I can print out a blow up of this particular valve to help me in the rebuild. Thanks PUTTER
HTR
10-21-2005 20:09:11
 Re: 4010 brake valve question in reply to PUTTER, 10-21-2005 07:32:29
You can get the breakdown of the valve, at JD parts on line. You don't have to register to view the parts books.
You didn't say what your serial no. was. There is some difference in the early and late valves. Here is a link to the later valve.
If I remember your earlier post right, I think your trouble is, no.52 boot leaked water in the valve, and caused no.46 guide to rust and stick. You can do the boot and guide repair without removing, and completely disassembling the valve.
PUTTER
10-22-2005 05:21:15
 Re: 4010 brake valve question in reply to HTR, 10-21-2005 20:09:11
Thanks HTR, I tried to find that at JD parts but couldn't find it. My serial number is 21T55699 , I think it's a 1963. When I start the tractor pressure builds up on the right brake peddle so hard I can't move the tractor. I,m going to rebuild the brake valve first but don't know if that will fix the problem according to other posts from this board. My brother, who is a better mechanic than I, is coming for deer season and we'll tackle it when he gets here. It's always great to take advantage of a younger brother. Thanks for your help, I'll keep you posted. Later PUTTER
