4020 Question
Cory R.
10-21-2005 07:04:24
Yesterday we were bringing our 4020 D home and it started belching white steam out of the engine breather what does this mean im new with the 4020 would apprecaite any help. Thanks to all.
Cory R.
10-21-2005 09:03:43
 Re: 4020 Question in reply to Cory R., 10-21-2005 07:04:24
G/Man the tractor was overhauled about 800 hours before we bought it. It was started every once in a while the oil is clean as a whistle just like you put it in and it doesent use any at all. It never gave the other owners any trouble and the steam was heavy there was lots of it, my brother said it looked like he had a fire at first because there was so much coming out of the breather. It puzzles me. Thanks for the help.
Mike M
10-21-2005 09:40:33
 Re: 4020 Question in reply to Cory R., 10-21-2005 09:03:43
Overhauled is a term that many people throw around like cars dealers use "low miles" "one owner" No way of really knowing for sure what was done unless you were standing there watching,or doing it.
WTW
10-21-2005 09:31:39
Cory, Remove your valve cover and look and see if there is lot of moisture / water hanging off it or you may even find white sludge which both are signs of coolant in system. Could be head gasket or liner packings leaking. After tractor has set for awhile crack oil drain plug and just let a little leak by plug to see if it is antifreeze. If you find it there better get your tool box a little closer to this project. Good Luck, DW
G/MAN
10-21-2005 07:41:17
Give us a little history on the tractor. Had it been sitting for a while? If so, it could be condensation in the crankcase boiling off once the engine got good and warm. Did it continue for some time, or just do it for a while and then quit? Was it billowing clouds of "steam" or just a small stream of puffs? Some vapor coming out of the breather tube is normal and unavoidable. I'd take a look at the oil and see if it looks like it's been contaminated by coolant. It will be milky in color if so. Kind of hard to make a judgement on this one without specifics. There are ways to check crankcase pressure and determine if blowby is excessive.
Mike M
10-21-2005 07:19:50
Sounds like you just got it warmed up and working hard and found out it's got serious blow-by. If after changing the oil and working it if it just keeps getting worse you need to budget for an overhaul.
Cory R.
10-21-2005 07:09:44
There is no knocking from the engine and the oil is clean and engine does not get hot. if this helps to get an awnser
Mike W J
10-21-2005 19:22:32
 Re: 4020 Question in reply to Cory R., 10-21-2005 07:09:44
Is the crankcase full of fuel ?
