1941 B SPARK PLUG HELP
G2 DEERE
10-20-2005 16:17:28
I HAVE BEEN TOLD THAT A D89D CHAMPION PLUG IS NICE AND HOT FOR SHOW ENGINES. I COMPARED THE D89D TO A CHAMPION D23 AND AC C88L. THE D89D IS ABOUT 1/2" LONGER IN TO THE CYLINDER AND THE WIRE IS SMALL IN DIAMETER THAN NORMAL AND IS NEXT TO THE CENTER ELECTRODE NOT IN FRONT OF IT. IS IT SAFE TO USE AND WILL IT HIT THE PISTON? I HAVE HEARD IT WILL START EASIER
buckeye al
10-21-2005 14:46:07
 Re: 1941 B SPARK PLUG HELP in reply to G2 DEERE, 10-20-2005 16:17:28
Like Puller said, the allegiance to a particular brand is much like the Ford VS Chevy argument.
I use Champion plugs in everything. Trucks, tractors, mowers, saws, weed whackers, hit & miss and even the smokey old twin two pony engines. No problems. I have D 23's in a 46Longhood A (my only nice looking parade tractor) that have been in service over 20 years. Use the right heat range for the job, keep the ignition systems up to snuff, run 'em reasonably lean, warm the engines up & usually plug fouling is not much of a problem. If the engine has "other" problems any "color" plug may foul. My experiences however will cause me to admit.... once fouled, a Champion for some reason seems harder to coax back to service than most. Why? I don't know.
Just the differences between fuel formulae across this land will make a difference in how these old machines behave. Use & stick with what works for you where you are & with what you're doing.
To answer your question will the piston hit the plug? Only if the engine has been modified.
jd b puller
10-20-2005 17:46:20
Spark plugs are like Ford vs. Chevy. I won"t put a Champion in anything but my competition"s tractor.
Suggest an AC87. Get them at NAPA. The 88L"s are real hot and kinda pricey. Unless you"re burning oil, stick with the 87.
