70D Standard air intake stack and wide fronts
DarylJ
10-20-2005 04:49:07
Was the air intake stack with pre-filter an option on the 70D? I have seen them both ways, with and without the intake stack? Was the adjustable wide front an option on the Standard 70D, or did the non-adjustable style give way to a later adjustable wide front end? Just curious...
Dan in Ohio
10-20-2005 11:18:44
 Re: 70D Standard air intake stack and wide fronts in reply to DarylJ, 10-20-2005 04:49:07
Daryl, I have a 70 D Std with air stack and adjustable wide front end. It looks as though it came from the factory that way. The parts book shows the air stack and adj. wfe as options. I also have a row crop 70 D with an air stack that was assembled from 720 parts and protrudes through the hood. Finding the original parts to set up the air stack for a 70 is not easy or cheap.
Blksmok
10-20-2005 08:12:33
Daryl...I don't "think" any 70's came from the factory with the precleaner. It was probably a dealer installed option where they cut a hole in the nose cone, removed the production air horn and then istalled the adaptor kit and preleaner stack. I've not seen any 70's with what looked like a factory punched hole for the precleaner. You will also see 70's with a 720 precleaner set-up where the hole is in the hood rather than the nose cone. On the adjustable wfe, I think that was factory installed option.
buickanddeere
10-20-2005 08:53:56
 Re: 70D Standard air intake stack and wide fronts in reply to Blksmok, 10-20-2005 08:12:33
A few of the standard tractors did have the adjustable axles. Nice find. It looks like the regular standard front end except the wheel bearings are mounted on a stub axle. This stub can be slid in and out of the main front end axle beam. The aircleaner stack reduced some of the dirt drawn into the aircleaner when used on the dusty Great Plains. My 70LP has a neatly field installed precleaner/stack. Felt better when I seen the other options like the tach and three point hitch.As for the rest of it..... ..... ..... .....
