520 fan shaft
Mike Siless
10-20-2005 03:54:26
I got a call from my neighbor to take a look at his 520. He said the fan and generator weren't turning and no power steering either. When I turn the fan by hand I can feel the shaft moving inside the long cover, so it seems it's disconnected back at the motor. I haven't taken one of these apart and was wondering is it a roll pin that connects the shaft back there, and do I need to remove the cover by pulling it out forwards (and remove the hydraulic pump, etc?) Any suggestions would be appreciated, I'd like not to turn this into a major project.
Mike Siless
11-07-2005 08:02:03
 Re: 520 fan shaft in reply to Mike Siless, 10-20-2005 03:54:26
It's been a couple weeks, but wanted to post a follow-up. I pulled off the LH cover and removed the governor gears. Everything was fine. By reaching in and rotating the fan shaft gear by hand you could tell that the shaft was rotating up as far as the PS pump. I loosened the PS pump and the problem is the splines on the pump shaft are worn, probably the coupling is bad too. Next is remove sheet metal and pull pump.
ChuckW
10-20-2005 09:29:07
In reviewing comments have worked on this very problem. I don't thing taking governor apart will help you and you will be doing exta work. There are two splined couplings. One in the tube ahead of the governor and one behind the PS pump. I think you just better resign yourself into pulling the sheet metal with gas tank, nose. Loosen the radiator and tilt to side. Put a piece of card board or light thing paneling in front of the radiator by fan(to avoid hitting radiator core when fan, P.S. pump comes off....then remove the rest of the tubing. I bet you find the shaft on the governor okay only to find the couplings wallered out. If the shaft is bad on the governor you can then remove the governor. Even it is worn some with a new coupling it will last for many years. Good luck. My opinion on repairs.
ET
10-20-2005 07:47:16
The splines are stripped in the fan shaft. Just like so many other spline drive couplers on hydraulic pumps drives. You will more than likly have to replace one or two if not all three splined shafts and the two couplers do to wear in the splines.
Mike Siless
10-20-2005 08:04:44
 Re: 520 fan shaft in reply to ET, 10-20-2005 07:47:16
Thanks ET, I just saw your response. When they were running it they heard a snap and it went all at once. I'll start at the back and see what I've got.
Mike M
10-20-2005 04:24:21
No roll pins,they use a splined coupling. The gear at the back that drives it is pressed on with a key. This has all the makeings of a major project. Some tractors you have enough room to sneak the PS pump out from behind the radiator and others don't then you have to start tearing off lots of pieces.
Mike Siless
10-20-2005 06:32:15
 Re: 520 fan shaft in reply to Mike M, 10-20-2005 04:24:21
Thanks Mike for responding. Would you guess then that the key in the gear sheared off, and I should start like you said by removing the PS pump? Thanks again.
Mike M
10-20-2005 07:29:46
 Re: 520 fan shaft in reply to Mike Siless, 10-20-2005 06:32:15
It would be very hard to guess what went wrong as anything is possible. I just wonder if pulling off the left hand governor cover and/or pulling out the governor assy. might be a good first step ? This will not take too much time to do,let you have a look at the gears,and if they have moved there's a good chance they are going to be chewed up and need attention anyhow. Pretty easy to put back in too. Just remember that the gaskets are also shims so try and save them so you can either stick it back together and walk away (LOL)or measure for reference to get new ones.
Mike Siless
10-20-2005 07:50:15
 Re: 520 fan shaft in reply to Mike M, 10-20-2005 07:29:46
Thanks Mike. You've given me a good place to begin. I'll start back at the governor, maybe I can avoid pulling everything off the front. Thanks again.
Mike M
10-20-2005 10:31:27
 Re: 520 fan shaft in reply to Mike Siless, 10-20-2005 07:50:15
The couplings could of let loose ? Good chance of it,but without a crystal ball I'd hate like heck to tear all that stuff off the front only to find out something could of let loose that drives the front. You also have a good chance of wasteing your time to pull off the LH gov. cover to see what turns and what doesn't ? In about 15 minutes you can narrow it down for sure is all I'm saying.
