weight of 4020
arnie1968
10-19-2005 15:17:52
does anyone know the approx. weight of a 1971 4020 hi-crop? i have to haul 1. nned to be sure i am legal.
thanks
Rodney A. Johnson
10-20-2005 06:09:45
 Re: weight of 4020 in reply to arnie1968, 10-19-2005 15:17:52
Per the owners manual I have from JD, the diesel, powershift, wide front row crop would run about 8600#. I figure with the cab I have on it, the 20.8 x 34 tires, and 3 wheel weights it would be close to 9400# (this does not count fluids...fuel, antifreeze, engine oil, hydraulic oil all extra).
Gassers, LPs, narrow fronts, or synchro-range transmission were all lighter (row crop).
Don't recall any specs on the standard/utility types.
barnrat
10-19-2005 17:06:08
From the factory the row crop weighed 8,555 lbs. My 4020 rowcrop with fluid and 500lbs of iron on each side weighs a little over 11,000lbs. So maybe that help with range of what one can weigh.
MSM
10-19-2005 15:43:22
I would figure in the 8000# range depending on weights,water in the tires,etc.
