Hand start B no fuel when choking
jdman(MO)
10-19-2005 15:02:48
Cannot get any fuel to the plugs after full choke and turning it over at least 9 times. I have did the following, Went through carb twice, then put it on another tractor and it started an ran perfect. Seems to have good compression, and will hold a vacum on the manifold for a least 4 seconds on each cylinder. Checked Valve timing. You can pull it and it will start, run and idle good. I have a good stream of fuel on the line going to the carb. Lastly I put another carb off a running tractor on it with the same results. Russ
jd b puller
10-19-2005 21:07:48
 Re: Hand start B no fuel when choking in reply to jdman(MO), 10-19-2005 15:02:48
I had this happen once. It was a bad gasket between the manifold and carb. The air leak won't let it draw fuel. Bad gasket between head and intake will do the same thing.
MSM
10-19-2005 15:52:11
Maybe a sticky impulse in the mag? Are you getting a good snap sound from the mag when spinning it over?If the mag won't impulse you can hand spin it til he!! freezes over. You eliminated a bad carb when you changed it out off another tractor.
