Hi fellas... Is there anyone out there using a 412 plow this fall? I could sure use some help on what to expect with my 412.Here's my situation. So far, I've lightly disced my sweet corn stubble and am trying to get the ground ready for the winter. This is only the second time this one acre praire patch has ever had a plow to it, I believe. The first time it was plowed was late this spring. I have a JD 412 model, 2 bottom, 14" cut, 3 pt hitch, with 16" high speed moldboards. I do have a JD 415 owners manual and am trying to use it a little bit to help me understand this plow, until I get a proper 411/412 plow manual. I live in east central kansas and am wondering how deep I should plow? If I was using the 40 or 420/430 tractor, how fast could a fella expect to plow? Maybe I just have a wimp tractor, Im using (please, excuse me), a 30 hp kubota tractor, 4wd and I can pull only 2.5 mph at 6 inches deep. It will dig 8-9 inches, but only at a crawl - I can barely pull it. My tractor's owners manual says my tractor is rated for 1-16 or 2-12 plow. I thought I could get by with this 2-14, but now Im not so sure. Also, I have set the mast at 12" measuring from the center of the mast to the right hand shoulder of the hitch bar and my lift arms are level and I landed the plow according to the manual, too. Oh, yeah, I have 17" coulters and they run true and cut well. Finally, my soil tests show this dirt to be good black soil, not clay or sandy....it grows great sweet corn! Any suggestions or comments would certainly be appreciated, especially these: 1- How deep should I plow? 2- How do I set the depth of the plow? Does the tractor lift lever control it or will it "float" at a certain depth if it is set right? 3- Should the toplink be somewhat loose, so to speak, while in plowing position? 4- How fast, in mph, could a 40 pull this plow when new or set correctly? Help! Thanks guys.... dwight
