4020 Engine Block
Bill A
10-19-2005 09:14:40
What are the tiny holes on the left side of the engine block for? It appears that there is one for each cylinder. It is a 4020 diesel.
MSM
10-19-2005 10:16:28
 Re: 4020 Engine Block in reply to Bill A, 10-19-2005 09:14:40
They are there in the event the cylinder liner seals begin to deteriorate and leak,the coolant will leak outside the engine and not in the crankcase.Antifreeze is death on bearings.
WTW
10-19-2005 10:13:34
Bill, There is a hole for each cylinder as you stated. These holes are weep holes for the liner packing / seals that seal the wet liner in the cylinder block. Each liner has two o-rings in grooves in block, weep holes are drilled in block to meet a third (empty) groove located between the two o-ring packings. In event the top o-ring leaked you would see antifreeze "weep" from this hole or if the bottom o-ring leaked you would see crankcase oil "weep" from the hole. It was an early indication that a liner packing was leaking and needed to be addressed. People did not like the mess they did create when they went to leaking and Deere decided to discontinue the weep hole. DW
Mike M
10-19-2005 10:46:59
 Re: 4020 Engine Block in reply to WTW, 10-19-2005 10:13:34
I bet they seen that the mud dabbers and grease plugged them up so they didn't work anyhow.
G/MAN
10-19-2005 10:50:52
 Re: 4020 Engine Block in reply to Mike M, 10-19-2005 10:46:59
Weep holes on water pumps tend to plug up too, and they're still using those. I think the block weep holes had a lot to do with those engines being Deere's first wet-sleeve engines and possibly a little aprehension that o-ring leakage might be an issue. It was a simple deal to drill the holes, and they provided a little cheap insurance against engine damage. Once it was established that the block design was good and that the seals were pretty reliable, they were probably deemed to be no longer necessary. The fewer holes you punch in a block, the stronger it is and the cheaper it is to make.
G/MAN
10-19-2005 10:37:02
I guess some people preferred to have the mess on the INSIDE of the engine rather than the outside, lol.
