2030 fuel guage
tgindiana
10-19-2005 08:49:27
Can someone sort out JD part numbers for fuel guage on JD 2030? My tractor serial number is 150743L, Type 2030, Code 2030A and was mfg. in Germany. Engine serial number is 189559CD, Type 4219GL and was mfg. in France. I bought a new sender for in the tank from JD dealer, part number AT20912 and guage part number is AL24187. Problem is guage will not read higher than 1/4 when tank is full. I tried three different guages (used)and all read the same. Sender puts out 30 ohms when float is raised (tank full). Zero ohms when lowered (tank empty). Hot wire on guage has 12.3 volts and connections on guage are clearly marked. When I ground the sender wire guage reads EMPTY. When sender wire is not connected guage is pegged. Ground on tank sender and guage check OK. I think I have wrong sender but JD dealer insists it is the right one and there are no others available. Has anyone ever run into this problem???
cannonball
10-20-2005 16:33:16
 Re: 2030 fuel guage in reply to tgindiana, 10-19-2005 08:49:27
have you gone to jd parts and looked...there are different gauges...one is Part Number: AT149002 Replaces Part: AR65444 Part Price: 86.90 USD Description: KIT FUEL GAUGE 30OHM Part Number: AL24294 Part Price: 108.90 USD Description: GAUGE need to look at jd parts....there are about 3 different 2030's.... have nice day may god bless
tgindiana
10-21-2005 05:45:23
 Re: 2030 fuel guage in reply to cannonball, 10-20-2005 16:33:16
Thanks Cannonball, I will check it out.
TG
