Evaluation of 1974 John Deere 1530 Tractor
John in OH
10-19-2005 03:03:28
I just purchased a 1974 JD 1530 Tractor with JD 145 Loader. Any comments from the John Deere crowd would be appreciated, including it's plus's and minus's. This is my first John Deere. I am more familiar with 800 series Fords.
Thanks
John
MN Bob
10-19-2005 06:28:23
 Re: Evaluation of 1974 John Deere 1530 Tractor in reply to John in OH, 10-19-2005 03:03:28
Always learn something from these sites. My book shows they were made in 74 and 75. 45 HP PTO and 39 DB. Question to Buick&Deere, What is "shiny flakes" indicating? Solution? Thanks
Mike M
10-19-2005 07:31:21
 Re: Evaluation of 1974 John Deere 1530 Tractor in reply to MN Bob, 10-19-2005 06:28:23
I guess if your filter was seen with "shiny flakes" it must be in Hollywood ?
Or your brake linings are eat up and chewing up the plates.
buickanddeere
10-19-2005 06:14:05
Check the coolant ph and the trans filter/screen for shinny flakes.
John in OH
10-19-2005 12:22:53
 Re: Evaluation of 1974 John Deere 1530 Tractor in reply to buickanddeere, 10-19-2005 06:14:05
If the PH is off and I find shiny flakes, what problems are these the symptoms of?
John
buickanddeere
10-19-2005 20:25:19
 Re: Evaluation of 1974 John Deere 1530 Tractor in reply to John in OH, 10-19-2005 12:22:53
Charlie1520
10-19-2005 05:20:48
I have a JD1530 that I've used for about 6 months doing mostly dirt work with it. It's been a great tractor. This is my first diesel tractor so I've wanting to see how well I like after this winter.(I believe that they built these tractors over 2 years, 1973 & 74.)
I also have a 1970 gas JD1520 that I've had for years. It's also been a good tractor but if the 1530 does well this winter I think that it will become my favorite.
Hope this helps.
Wayne H
10-19-2005 04:36:59
I have a friend with a 1530. They only made them one year. I just used his last week to spread fertilzier, and it worked like it was new. His has no issues other than the paint is faded and there is some rust from the calcium on the rims. It shifts fine. The clutch works great. The clutch on that engages the pto first, then the drive train, so if you push it down all the way the pto stops.
His starts up with almost no cranking, and has a little smoke when cold. The lever for raising and lowering the 3 pth is not as smooth as I would like, but probably just needs oil. Anything else you need to know?
Wayne
