BAD THREADS
Mixman
10-18-2005 18:25:17
I am working on an unstyled John Deere A that as I know as the water jacket (bottom of the head) threads are gone. I can repair this several ways but I thought maybe someone has been thru this and can advise me. I want to be able to drain this tractor when fixed.
Mixman
10-19-2005 19:33:21
 Re: BAD THREADS in reply to Mixman, 10-18-2005 18:25:17
Thanks guys you've been very helpful
F-I-T
10-20-2005 06:29:04
 Re: BAD THREADS in reply to Mixman, 10-19-2005 19:33:21
Mixman:
If you are able to borrow a tapered pipe tap from your local plumber, you'll likely only have to turn it one turn, maybe a turn and a half until you have all fresh threads. Then you can use the original plug if you wish. Put a little grease on it and it will likely last another 50 years. I"ve fixed too many to count and a two turns at most because of the taper will give you new threads.
Frank
Bob
10-19-2005 17:25:47
Run a pipe tap in there, to clean up what threads are left.
Get a BRASS reducer bushing to fit the remains or the original threads.
Clean up the hole and bushing with carb cleaner to remove any traces of oil, and dry with compressed air.
Apply JB Weld, or other favorite epoxy, to the old threads and the outside threads on the brass bushing, and install it in the damaged threads, and allow the epoxy to harden for at least 24 hours. You now have fresh new threads one size smaller than the originals, and they're brass, and will not rust out. Simply use the next smaller pipe plug.
Steve Smith
10-19-2005 17:07:06
It is pipe thread. I forget what size. I found a reducer that would fit. I used JB-Weld on the threads of the reducer. Screwed it into the water jacket. Then a 1/2 inch pipe plug in the reducer for a drain point.
Steve
Maark
10-19-2005 14:40:51
Those threads are pipe thread.They are tapered i think. I have screwed a pipe nipple in the hole and put a pipe cap on them.
Walt in Jaxn Tn.
10-18-2005 19:01:28
Are you talking about the threads in the drain plug hole?
