Anyone walk me through tapered hitch bushing?
Nylon
10-18-2005 17:20:59
I did a search for bushings here and can't come up with the magic words. I know it has been discussed here before.
I need to stop the constant hydro loss out of my three point. I bought the tapered bushings with the o ring. I know that it shouldn't be too bad but one little glitch can leave your machine siting imobile with no hydro fluid.
BTW 4020 diesel synchro
I haerd that a shaft needs to be replaced when doing this too as well as some seals. Anyone have an exloded parts diagram? Also anyone talk me through the best way to accomplish this job? I remember reading some posts with trouble getting something out or off. I want to be prepared and have everything I need on hand and ready. I don't want to pull it apart and find I need something else or that I cant get something to come off. Any info on potential pitfalls or work arounds mujch appreciated.
Thanks,
John
Glen in TX
10-18-2005 22:32:50
 Re: Anyone walk me through tapered hitch bushing? in reply to Nylon, 10-18-2005 17:20:59
3 illustrations on Parts & Pieces. JD also lists some oversize bushings if the bore in case is wore.
Glen in TX
10-18-2005 21:23:22
Get some shim washers from JD too regardless of where you decide to get the seals, bushing, and shaft from.
http://www.boling-machine.com
http://www.boling-machine.com/instructions.html
http://jdparts.deere.com
I&T manuals here and other vendors
Jason Z in MO
10-18-2005 18:57:25
John,
I think if you do a search on "load control shaft" it will reveal the information you are looking for. Here is a link to the conversation we had about it a few months ago.
Link
Did you replace your brakes yet? Or try to move the wheels on the axles? to get to the load shaft its best to have them out toward the ends of the axle.
Also I didn"t mention it in the previous post but those new bushings have an inside taper so they are directional. You should have gotten instructions explaining it.
About the parts book. Are you aware you can access the parts books for your 4020 on JDPARTS Select the "John Deere Parts Catalog" on the left. Do a model search for 4020 and you"re on your way! This site doesn"t have the books for the 2 cylinder era but is really handy for New Generation to current.
Hope this helps,
Jason
barnrat
10-18-2005 19:30:15
 Re: Anyone walk me through tapered hitch bushing? in reply to Jason Z in MO, 10-18-2005 18:57:25
When you get the bushing and seal kit. I believe it has the instructions for how to do the repair. I also know that the bushing and seal kit for the load control shaft is an aftermarket kit sold through John Deere, so it might not show up in the parts book. I've also have done this repair manay many times so if you have questions contact me.
Nylon
10-19-2005 00:41:02
 Re: Anyone walk me through tapered hitch bushing? in reply to barnrat, 10-18-2005 19:30:15
Thanks for the great info guys. I did get the wheels moved out. It was a bugger. I took them all apart and cleand and anti seized everything. Works nice and smooth now except I need one "push" bolt as threads were gone on one of them.
I got the tapered bushings off e bay..spose I got took a little but I was looking at it and decided there they were and had to do it. I have to get the seals yet. And the shims are good to know about. This tractor spent its life as a loader tractor....would the load shaft likely need replace or is it cheap enough just to have the part in case it is needed?
I guess I am wondering how you get the old bushings out and the new ones in? Hopefully no special tools. This guy on e bay was selling some type of shaftlock...like threadlocker? Anyway, is there something in there that requires this stuff? I have an I&T manual but was vague the first time through. Will try it again. My wheels are currently all the way out. Brakes have not been attempted yet.
Thanks much again I am going to read that link to those threads now.
John
Nylon
10-19-2005 00:53:48
 Re: Anyone walk me through tapered hitch bushing? in reply to Nylon, 10-19-2005 00:41:02
I read that post from Jason. So you take the end caps off and then you simply drive out the shaft? then drop the yoke and you can see the seals and bushings? Push them out from the opposite side with pipe/rebar. Where would the shim washers go? On the ends of the shaft if there is free play? How "snug" should it be?
How tough is it to drive out the shaft and how tough is it to get the seals and bushings into the housings? The taper go to the inside? I haven't actually recieved the bushings yet.
Also Glen mentioned oversize problems.
Thanks,
John
Glen in TX
10-19-2005 11:46:02
 Re: Anyone walk me through tapered hitch bushing? in reply to Nylon, 10-19-2005 00:53:48
Nylon, The shims are used between the Y shaped frame and the outer tractor case. You don't want the Y frame wobbling back and forth later as it will knock the seals out again soon. I saw the oversize bushings in the parts listings but never used them that I remember. Believe the oversize is the OD part if bushing has worn some in trans case. About 3 or 4 oversizes listed so you would need to do some measuring if your old ones just fall out but I've never seen that yet. Someone was mentioning about new bushings going in the trans loose and needing locktite on outside or shim material but that is why they made oversize bushings and why it's good to get it apart for inspection first. I&T is kinda vague on this. Go by your JD dealer with your 4020 serial number in hand and get a look inside the tech manual for it as it should give some dimensions for the shaft and bushings. Maybe they can copy a page or two for you on that? They only recommended replacing the bushings when worn beyond limits and replacing them everytime is what gets the trans case bore worn. If the shaft is within tolerance you can polish it with very fine emory and scotchbright pad. If shaft is scored some replace it. If you have to replace the bushings chilling them before installation will make them go in easier. JD 6030 tech manual recommends to heat the sealing ring in 160 degree water before installing. Check 4020 manual on that. All it says on side clearance of yoke is to shim for minimum clearance. Use lots of oil to lube the seals and shafts when installing. Good luck.
Tx Jim
10-19-2005 03:51:35
Nylon,the shaft is not hard to get out if you put draft control lever in D. You can use a jack or come-along to support yolk. Shim washers go between yolk and trans.case. If shaft has noticable wear it needs replacing. I never understood why JD engineers wanted to put 2 little thin seals on bottom of oil reservoir. Tx Jim
Mike M
10-19-2005 07:36:29
 Re: Anyone walk me through tapered hitch bushing? in reply to Tx Jim, 10-19-2005 03:51:35
I guess they figured they had to leave at least one way to destroy them and/or sell millions of gallons of Hy-Gard.
Glen in TX
10-19-2005 11:49:48
 Re: Anyone walk me through tapered hitch bushing? in reply to Mike M, 10-19-2005 07:36:29
Well...how many engineers will you see on the shop floor under something greasy and dirty?? lol. A neighbor does engineering and farms on the side and I give him a bad time when I see him greasy. lol.
Nylon
10-19-2005 21:08:40
 Re: Anyone walk me through tapered hitch bushing? in reply to Glen in TX, 10-19-2005 11:49:48
So...I agree that is a bad place to make a couple of holes. What have they done to the new ones so that isn't a problem?
John
Mike M
10-20-2005 04:53:01
 Re: Anyone walk me through tapered hitch bushing? in reply to Nylon, 10-19-2005 21:08:40
A tractor just a little newer,like maybe a late 4020 or even the 30 series were very similar but used some kinda real hard plastic of some type fit in like an o-ring kinda ? These did seem to hold up better. Also JD wasn't the first to run a shaft through the bottom of a tranny case and try to seal it up. Others ran the clutch/brake shafts through there.
Glen in TX
10-19-2005 21:21:03
I think the new ones have it all controlled with electronic components somehow. Just a new set of problems maybe?
barnrat
10-20-2005 05:05:41
 Re: Anyone walk me through tapered hitch bushing? in reply to Glen in TX, 10-19-2005 21:21:03
Some companys have been using electronic sensors for load sensing for about 25 years. The units a virtually indestructible, extremly sensitive, make no hole into the transmission, and are very reliable. I can't remember when Deere started using them I'll hafta look in one of my old textbooks but I think it was on the 55 series
Glen in TX
10-20-2005 13:33:33
 Re: Anyone walk me through tapered hitch bushing? in reply to barnrat, 10-20-2005 05:05:41
Well, maybe? I've seen a lot of the first red ones dropping plows going down the highway and some bad accidents from that too. So none of them are fool proof yet.
