Using the measured numbers he provided for the piston diameter and cylinder diameter, subtracting them, and dividing by 2 to get the piston/cylinder clearance, I get the following numbers: parallel to pin top 0.024 middle 0.014 bottom 0.010and at 90 deg to pin top 0.024 middle 0.007 bottom 0.003 SM2020 notes that "usually when the piston to cylinder clearance exceeds 0.018 inch it will be necessary to replace or rebore the cylinder block to maintain compression and oil control". So, it depends in particular where he measured the top, as that is the measurement out of spec. I don't know which of his "top" or "middle" is closest to "top of skirt above pin", but probably the "middle" measurement should be used. The information for the pistons in SM2020 differs from SM2017. Comparing them: SM2017 (SM2020) [his #] Top of skirt above pin along pin 6.1086-6.1096 (6.1018-6.1028) [top 6.082, middle 6.101] 90 deg to pin 5.9998-6.1108 (6.1083-6.1093) [top 6.083, middle 6.114] and bottom of skirt along pin 6.1153-6.1163 (6.1085-6.1095) [6.105] 90 deg to pin 6.1165-6.1175 (6.1150-6.1160) [6.118] So it looks like the top and middle of his piston along the pin is worn beyond specs, and at 90 degrees his piston is too big(6.114, 6.118) in both directions at the bottom(?). Based on this info (don't understand the large piston measurements at the bottom 90 deg) I guess he needs to at least replace the pistons - or calculate the clearance with new pistons and present cylinder bores to check specs. A homework assignment, I guess. Finally, in regards to his original question concerning the clearance between the piston and cylinder on new equipment is greater than the posted acceptable clearance (0.0242 vs 0.0150-0.0174), I don't understand that either. It seems too large to be acceptable - a misprint or error on JD's part?
