follow-up, distributor shaft oiling (50)
55 50
10-17-2005 18:54:29
Back on page 3 or so I asked about distributor shaft oiling because my 50 had a squeak in that area. Well I added some oil in that distributor and the squeak went away so it was really time to service it.
Mike M
10-18-2005 04:36:35
 Re: follow-up, distributor shaft oiling (50) in reply to 55 50, 10-17-2005 18:54:29
I've also had them squeak at the points rubbing block from being dry. A little dielectric grease behind the rubbing block cured them.
55 50
10-18-2005 08:18:44
 Re: follow-up, distributor shaft oiling (50) in reply to Mike M, 10-18-2005 04:36:35
Mike, Good point. I completely forgot to mention that I also added a liitle grease to the cam that moves the points so maybe that was what stopped the squeak. Guess I"ll never know now!
Mike M
10-18-2005 09:25:15
 Re: follow-up, distributor shaft oiling (50) in reply to 55 50, 10-18-2005 08:18:44
I'm betting it was the points.
Duane Larson
10-17-2005 19:47:32
55 50,
Thanks for the follow-up - sounds like your problem is solved.
