DLTX carb
Ivan in Mich
10-17-2005 17:26:16
Could someone tell me what the number on the carb is for example DLTX 10? I just bought a 1951 JD B and it is missing the carb I have a parts B that is a 1939 or 40 and was wondering if the carb off it would fit. Thanks for any help I can get. I plan on fixing the 1951 B up
DickD
10-18-2005 16:33:14
 Re: DLTX carb in reply to Ivan in Mich, 10-17-2005 17:26:16
Ivan; I have a good rebuildable DLTX 67 which is what you need for your late model B. I would be willing to trade for your DLTX 10 if it is in equal shape, as I need one to complete my 39B. Let me know if you are interested. I am located in NC Indiana
JGC
10-18-2005 14:11:41
My understanding is that the all-fuel carbs are "jetted" for "distilate' which has a different density than gasoline. Roberts Carburator (SP) {Google it} has some details about this and I think they sell the "jets".
I run an all-fuel "D" on gas with the original all-fuel "jetting".
It seems to run just fine, but probably not optimum!
Jon
Skyhawk Greg
10-18-2005 08:21:47
Ivan, The older carb is probably a DLTX 34. It will work on the newer model of B where a DLTX 67 was installed. The DLTX 67 is a gasoline only carb, and the DLTX 34 is an all-fuel carb with an economizer built into it. They both should hook up the same. I don't have the book in front of me now, but perhaps the main jet is a different size from one carb to another. I doubt you will notice any difference under most circumstances. Try it. It sure is cheaper than the $250 to $400 alternative!
ChuckW
10-17-2005 17:49:06
The carb might fit but is not calibrated for the engine. For your tractor you need a Dltx67 if it is a gas burner.
