4cyl , early 1950s; JD Dubuque engine
WV2cyl
10-17-2005 16:46:50
At a show in McConnelsburg Pa this weekend there was a LA that was converted to a 4 cyl engine. Various shortening and frame and hood lengthing was done. The interesting thing was the engine, which the gentleman said came out of an early 1950s combine, maybe a pull type model 20. The engine was most definately modeled from a Dubuque M-40 engine but was 4 cyl. The fan, generator mount, bell housing, everything was the same. The water outlet is the same with an extra one mounted further back on the engine. Has anyone ever seen one? Can someone enlighten those of us who looked it over and are wondering what we have seen? Several of the gentlemen present,were very knowlegable about JD tractors and engines, had never seen or heard of such an engine.
Mike M
10-18-2005 04:43:15
 Re: 4cyl , early 1950s; JD Dubuque engine in reply to WV2cyl, 10-17-2005 16:46:50
My uncle has a couple of them (bad shape)in old 25 combines. I always thought they were a dead ringer for the M engine and thought it would be neat to put one in an M or MT.
105Diesel
10-17-2005 17:24:13
Most likely it was powered by a HA-92 Power Unit from a 25 or 30 Combine. The HA-92 was Deere's first 4-cylinder engine, and was introduced as a power unit for combines and balers in 1952. These engines displaced 92 cubic inches and had about 25 horsepower. They did share some design features of the "M" engine, though scaled down a bit, and if memory serves, had the same bellhousing bolt pattern as a "LUC" Power Unit, which was basically the same engine as used in the "LA" Tractor.
