4440 FWA advice needed
OzRinger
10-17-2005 01:55:52
Hi There,
I was looking for a tractor around 150hp and a 4440 front wheel assist tractor has come up for sale...It is a fair way away from me so before I go to look at it I thought I would look up JDPARTS to see what I could find out about it...
What I found was disturbing...It seems going by the parts breakdown that although it has front wheel drive it is not of a conventional design with a drive shaft and diff but rather it has two hydraulic motors driving each wheel...
Is what I have found for real???? I don"t want to buy it if it like this, as a front wheel drive system of this design sounds very very expensive to repair if something goes wrong(especially for a 25yr old tractor)
any other info about the 4440 model would be appreciated also...
Thanks.....
OzRinger
10-17-2005 16:05:43
 Re: 4440 FWA advice needed in reply to OzRinger, 10-17-2005 01:55:52
Ok Thanks for that everyone...I don"t think I will go look at this one now....
I"ll see if I can find one with real front wheel drive like a 4450, 4255 or even a 7110 Case(I don"t really need 150hp around 140 engine hp will do)
G/AN
10-17-2005 10:21:42
If you're looking for 150 horsepower, technically you should be looking at 4640s. Yes, most 4440s will knock down 150 horsepower any day of the week even without "tweaked" pumps, but the 4640 was rated 155 from the factory. And the bonus would be that 4640s seem to bring quite a bit less money, at least in this area. A 4640 is bigger, bulkier and not as handy as a 4440, but they're much stronger in the powertrain. The PFWD (hydraulic front assist) wasn't the do-all and end-all for front-wheel-assist, but it did was it was intended to do, i.e. add some drawbar pull and increase traction somewhat. It's an electric-over-hydraulic system with the oil being supplied by a bigger main hydraulic pump than a regular 2wd got, although I do believe the bigger pumps became service replacements for all tractors. And yes, any time you add hoses, lines, or other hydraulic components, you increase the number of potential trouble-spots and add more places for leaks to form. The system is more or less similar in form and function to the "mud-hogs" put on the back of combines and self-propelled forage harvesters. I don't think they built scads of 4440s with PFWD, so from a future-value standpoint, it COULD be a wise investment, when those tractors become collectibles, as they surely will.
JDknut
10-17-2005 08:58:33
The 4440 is arguably the best tractor ever made, but the HFA stunk. I know someone who converted it back to a conventional fromt axle. Now the 4450,is another story, it had the great Caster Action MFWD, if you could find one of those, that is the best of all.
Mike M
10-17-2005 05:31:05
My uncle had one of those on a 4230. Just don't plan on leaveing it run full time as it was only made for an "assist" to get through the bad spots. One winter I remember of him saying that if he tried to run it all the time the hyd. oil got real hot. He was also running a loader too.
Scotmac
10-17-2005 04:49:20
The hydraulic fwd front end is removable...and there is some value to it. Some guys are buying them and making 4020 console fwds...lots of different applications for that particular unit if you don't want it. One sold on Ebay this last spring for an outrageous price for it's condition. Or....you could just leave it on the tractor. It's deductable...but...so is giving to your local church!
MSM
10-17-2005 04:27:36
Yes it is hydraulic assist. They worked adequately,but it is not the same as mfwd. They are prone to leaks,and can cause some problems due to all the wiring and switches used to activate it. Alot of people have removed the front end,capped off the lines and install a regular wide front. Aside from that the 4440 is an excellent tractor,assuming it has had good maintenance,and hasn't been overfueled and used beyond it's designed capabilities.
