Deere 'R' Serial Help
Brand0n
10-16-2005 20:03:06
I posted to Smokstak not long ago about my Deere and lost serial number. I can tell its a late production by many of the features but I would still like to have an idea what animal Im dealing with. Are there any alternative locations for casting numbers, date codes or other identifing numbers to look for? The Magnoodle serial plate is painted over with several layers of enamal and I doubt its even stock.
Ideas on this one?
Also is there a 3-point hitch that can be modified to fit from something that might be close? Ive looked at some of those other aftermarket hitches but most are pretty mangled up even for me.
Thanks in advance
parrothead
10-18-2005 05:51:12
 Re: Deere 'R' Serial Help in reply to Brand0n, 10-16-2005 20:03:06
I don't know of any possible way to mount a 3pt on an R. I guess that you could make a 3pt trailer rig and tow it behind the R. You could run it with a hydraulic cylinder. If you want a 3 pt with a diesel, you probably need to pick up a 730.
Glen in TX
10-16-2005 21:03:36
I don't if anyone has a way to date mags on pony by serial numbers or not? Probably not but someone might? Not me. Otherwise if there were changes or options compare with serial numbers in a parts book maybe? Sounds like you should have bought one with a serial number and a 3 point.
