Has anyone tried this?
TG
10-16-2005 18:58:07
Most of my cows are several miles from the house. I use a tractor mounted 3 point round bale mover there.
I was just able to get a few acres next to the house and want to feed round bales to a few cows on this new place, but the tractor at home is too small for a 3 point bale mover.
Instead of moving to a larger tractor at home, I"m looking at getting a bumper pull, two-wheel, single-bale buggy; disabling the hand cable winch, and adding on a remote hydraulic cylinder to hoist the round bales with.
Has anyone done or seen this done. Any comments on this idea??
Thanks
Kmiller
10-17-2005 19:12:01
 Re: Has anyone tried this? in reply to TG, 10-16-2005 18:58:07
Just for another alternative, I hooked a cable to the 3point drawbar and raised it up that way, but it didn't have enough travel to raise the bale very far. It worked ok, but I wouldn't take it out on the road with the bale barely off the ground. Just food for thought if you don't want to bother with the hyd. cylinder.
Kerry
J.P.
10-17-2005 14:12:38
You should have plenty of travel even with a short cylinder. It just depends on where you mount the cylinder; the closer you get to the pivot pion the more travel however you also increase the power needed to rotate the lift and the torque on the mounting brackets. You may have to beef it up a little at your mounting points.
Glen in TX
10-16-2005 21:19:21
Electric winch sounds good to me. You'll have to have a long cylinder and/or weld some more brackets or linkage on I suppose. Maybe not if you don't want to lift it very high. Used one of those sliding rolling one bale rigs with the electric brakes but they don't work good in snow and ice or didn't for me.
N. TX Tim
10-16-2005 20:57:23
Haven"t seen it done...but I don"t know if you will have enough travel with a run of the mill cylinder. You could also try an 12V electric winch...it would serve the same purpose but not as fast...and don"t know how the cost would compare...
Tim
