310B Backhoe can't find hydraulic oil fill point
Gunderlaney
10-16-2005 02:28:36
I have recently purchased a 310B Backhoe loader and cant find where to put in hydraulic oil. I've changed engine oil and topped up the transmission oil, but cant locate the filling point for the hydraulic system. What else should I be keeping an eye on excluding general greasing points?
Gunderlaney
11-11-2005 17:21:49
 310B Backhoe change of hydraulic /transmission oil in reply to Gunderlaney, 10-16-2005 02:28:36
Have the right oil now, wondering the best way to drop all the oil out of the Hydraulic / Trans system as current oil is burnt and don"t know when last changed. Found the sum drain and have new filter but was wondering best way to get bulk of oil from all the lines? Any easy ways to do this?
MSM
10-16-2005 08:17:36
 Re: 310B Backhoe can't find hydraulic oil fill poi in reply to Gunderlaney, 10-16-2005 02:28:36
The hydraulics and transmission use a common sump.You fill it through the dipstick/fill tube located in front of the seat by your right heel.Use Hyguard or a good quality universal tractor fluid,not hydraulic oil.
Keep the antifreeze clean and use a coolant conditioner,those engines are prone to pinholing the liners when the cooling system isn't maintained.Other than that just good maintenance practices and grease it daily.
Steve Crum
10-16-2005 15:36:20
 Re: 310B Backhoe can't find hydraulic oil fill poi in reply to MSM, 10-16-2005 08:17:36
Must be one of those obscure differences between a 310A and a 310B. My hydraulics fill cap is behind my left heel. (I even went and checked) picky..picky..picky. But MSM is correct, use only the Hygard or a top quality equivelent. You'll be much happier with the extra expense, versus having to go into the transmission/hydraulics on one of these.
For grease I use only the black moly. Used it since I bought the machine new in 1979. Everything is still tight except the front pitman arms. A Deere engineer should have been strung up for that design.
