318 stops running, appears electrical-what to look
Oldjeepinprogress
10-15-2005 06:18:58
I'm trying to help my father figure out what's going on with his 318 garden tractor. He uses is for mowing and right out of the blue the motor just dies like he turned off the key. Then when turning the key to restart, nothing happens. Headlights and dashlights work. Appears to be a safety switch issue or something electrical. "For testing purposes only," (yea right) we have bypassed the seat sensor switch with a wirenut. Also the last time he did get it started again, as soon as he move the drive lever out of "N" it killed instantly. He put it back in "N" and it continued to run. Any ideas where to begin? JD parts are expensive so I don't want to buy any unneccesary parts. Thanks.
Pete/ME
10-16-2005 03:59:04
 Re: 318 stops running, appears electrical-what to in reply to Oldjeepinprogress, 10-15-2005 06:18:58
May sound totally wacky, but something similar happened to my 316 a few years ago. Lifted the hood and found behind the headlights a mouse nest, and the critters had knawed through enough wires to create a sporatic short...worth a look.
Ben48A
10-15-2005 18:08:08
I would just unhook all the safty swithes and that shoud stop the problems
CNESLER
10-15-2005 07:53:51
The seat switch shorts out the ignition.
To bypass this device just unplug the wire.
Good Luck
CNESLER
stu in njo
10-15-2005 10:30:48
 Re: 318 stops running, appears electrical-what to in reply to CNESLER, 10-15-2005 07:53:51
If you wire nuted the two wires together the ignition is shorted. hope this helps Stu
Wayne H
10-16-2005 15:31:47
 Re: 318 stops running, appears electrical-what to in reply to stu in njo, 10-15-2005 10:30:48
I had had the exact same problem with my 318. It started when my wife was using it, which I assumed was her fault. Then it did it to me over and over. It would start when cold, run for 10 minutes and quit.
Now the bad news. I fixed it. I think if you check, when it stops running you will also have no spark. I had to change the electronic ignition assemly that is BEHIND the flywheel, which means you need to pull the engine, which really is not that bad. I tried the coil first you can be sure...
What happens is that after many years, the magnets on that electronic ignition thing get week, and as they get warm, they just get below the threshhold where they will work.
Good luck
Wayne
