Gasoline kit for G
Roy Hobbs
10-14-2005 18:02:45
When Deere changed to gasoline from the allfuel engine in the A and the B model,they stayed with the allfuel model for the G.Later Deere offered kits to upgrade to gasoline.Can anyone tell me exactly what came in this kit? I assume pistons,but what else? Thanks
Duane Larson
10-14-2005 21:11:43
 Re: Gasoline kit for G in reply to Roy Hobbs, 10-14-2005 18:02:45
Roy,
Two of my AC1000 Attachments catalogs (1-55, 11-56) both list "conversion set, gasoline burning", which includes 1 AF1323R manifold, gasoline conversion and 1 AF1324R Pistons with rings. A second set is offered, the only difference being the pistons and rings are 0.045" oversize.
An earlier AC1000 (8-52) lists conversion kits for the A, B, and D, but not the G.
Finally, I have a sheet which appears to be from a Service School titled "Procedure to High Compression Model "G" Tractor Serial G13000 & Up". That involves changing the head and valves back to the last unstyled one, and using a gasoline manifold "supplied by order from Grinnell Farm Equipment"
Roy Hobbs
10-15-2005 13:20:42
 Re: Gasoline kit for G in reply to Duane Larson, 10-14-2005 21:11:43
Glen,Frank&Duane, Thanks for the help.I'm wondering if you can tell the difference between the two manifolds by appearence? I bought a nicely restored 48 G and never thought to ask the guy about this. I guess this would be the easiest way to tell if this tractor was upgraded? Thanks again.
Duane Larson
10-15-2005 14:24:47
 Re: Gasoline kit for G in reply to Roy Hobbs, 10-15-2005 13:20:42
Roy,
Yes, the manifolds look different. The all-fuel manifold has a casting number F552R. Several "cold" manifolds were available for gasoline conversions and have less cast iron. Pictures are often shown in Green Magazine or Two Cylinder advertisements.
F-I-T
10-15-2005 14:18:00
Or run a compression check. If it has gas pistons in it she ought to have comresiion exceeding probably 100 psi.
Frank
Roy Hobbs
10-15-2005 16:33:09
 Re: Gasoline kit for G in reply to F-I-T, 10-15-2005 14:18:00
Frank, I had thought about doing a compression check,but was'nt sure what numbers I should be looking for.Tomorrow I'll check the manifold for the casting # Duane gave me and we'll do a compression check also.I really appreciate you guys helping me out. Thanks again
F-I-T
10-14-2005 22:23:49
Duane:
I could not find that in the AC-1000. Possible my reprint just didn't include it? Or did I look in the wrong area. I looked under the Model "G" section.
Frank
Duane Larson
10-15-2005 06:39:27
 Re: Gasoline kit for G in reply to F-I-T, 10-14-2005 22:23:49
Frank,
What is the date of your AC1000? It is not in the 10-58 nor 11-59 versions I have. It is under the Model G, Engine section in the earlier editions.
F-I-T
10-15-2005 08:37:28
 Re: Gasoline kit for G in reply to Duane Larson, 10-15-2005 06:39:27
Duane:
10-58. They must have figured that any G's needing converted would have been converted by then, so they stopped listing the kit.
Frank
F-I-T
10-14-2005 18:49:16
RH:
I looked in my AC-1000 "Accessories" book and did not find a complete whole goods kit, but there well might have been. However, the parts book lists pistons and manifold for gasoline for S/N's G-13000 and up. I did not find any gas parts under the carburetor. BTW, the stock sized pistons were number F1075R and the manifold for gas was AF1323R. They also offered .045" over.
Frank
Glen in TX
10-14-2005 21:26:31
 Re: Gasoline kit for G in reply to F-I-T, 10-14-2005 18:49:16
Roy & Frank, You might find a kit # in a later G parts book? I'm not sure if the G used a different gas manifold also. They did change the nozzle in the DLTX-51 carb to a 47-649 / R10126R gasoline nozzle and a "E" econimizer plug. The same nozzle & plug was used for gasoline conversion in the D with a DLTX-63 carb and high compression pistons and the gas manifold. D parts book listed a AD2870R gasoline conversion kit and something simular may have been available then for the G.
