How many different Deere quick couplers?
Nylon
10-14-2005 17:40:04
I need to come up with 4 female deere quick couplers that are equivelant to the rear dual remotes. I was in Fleet Farm other day and did a quick look and saw something that said deere new style. I prefer changing everything to pioneer but I am going to use the same hose and connectors on my loader currently to couple to a joystick. What I have certainly must be the old style. Is there more than the old and new? ie 2 different styles?
Also I did quick couplers at the tee for supply and return so that if the cab has to come off for any reason I can plug the loader into the rear remotes and unplug the joystick right at the T so it can go with the cab. The couplers I got from the guy who is making my hoses gave me the type with a conical spring for a coupler. The spring doesn't seem too stout under the cone. At least compared to a pioneer ball in a quick couple. What do you guys think...is there a real difference between these coupler styles?
Thanks,
John
Bob
10-14-2005 20:22:55
 Re: How many different Deere quick couplers? in reply to Nylon, 10-14-2005 17:40:04
If you want to go the the "new" Deere-ISO-Pioneer couplings, you can get kits from Deere to change the barrels in the 4020's coupler bodies to accept the newer standard tips.
Nylon
10-14-2005 22:19:41
 Re: How many different Deere quick couplers? in reply to Bob, 10-14-2005 20:22:55
I have the old style on my loader lines and want to keep them. I have adapters for the rear remotes to couple with pioneer when I run implements (I have access to lotta implements ..not mine and they are all Pioneer). I want to be able to hook my loader up to the remotes if I need too again. On my new joystick I am going to make enough hose to get out of the cab and put on the same old jd female couplers. That way I can uncouple the loader and uncouple at the supply T and the return T. Joystick can then come off with the cab and I can plug loader into rear and still run.
It sounded from your post like jd and pioneer went to an all new coupler that will acomodate both a new style JD and a new styled pioneer? But they won't accomodate either jd or pioneer old stlye?
Bob
10-14-2005 23:01:05
 Re: How many different Deere quick couplers? in reply to Nylon, 10-14-2005 22:19:41
The replacement barrels I was referring to will accept Pioneer-style tips, but NOT the older Deere-type tips.
When you are looking at older couplers, be aware that there are Deere-style tips out there made to Deere spec's by Pioneer, and marked "PIONEER".
Nylon
10-15-2005 00:23:01
 Re: How many different Deere quick couplers? in reply to Bob, 10-14-2005 23:01:05
That is what I gathered but good to be reassured.
Are the steel ball type tips better than the cone type ? Any idea or doesn't make any difference?
The other thing I'm still not clear on is that the new style deere tips wont fit old style deere tips? I am guessing that they don't but just to make confirmation.
Thanks for the info on the barrels as it may be convenient to convert something somewhere sometime. Thanks,
John
