4455 mfwd G-MAN????
TIMAR
10-14-2005 17:28:55
Need to hear from any JD mechanics. I was subtilling last night with a Blu-jet 5 shank Subtiller. When I would hit tough ground, the MFWD acted like it was slipping. Does it have a separate clutch system that could be going bad? I am pulling it pretty hard and I have it weighted down pretty heavy. Unit weighs 19,500#s. I have 650-65r-38's on the rear full of fluid and fluid in the fronts also. Reason for the fluid in the front is that I need the tractor for a 740 loader also, and I can't use front weights. Last night I had the loader and bucket mounted on the tractor because the last time I was out, the front tires would spin out alot. Am I expecting too much? The ground I am working is pretty dry and I just had tiles put in on it, but had the dozer rip where he had pushed the terraces up. Gyrha did it by the way G-MAN.
G/MAN
10-17-2005 07:31:16
 Re: 4455 mfwd G-MAN???? in reply to TIMAR, 10-14-2005 17:28:55
Even when heavily loaded, the MFWD shouldn't tend to slip if everything is okay, but it sounds like you're sticking it to the ground pretty hard. I'd be interested to see what your wheel slip percentage is - 8%-12% is ideal for maximum efficiency and minimum wear. Any less and you're seriously straining powertrain components as the slippage helps cushion them from shock. The MFWD clutch is spring-applied and hydraulically-released. A stack of Belleville washers apply tension to the clutch disks and plates, which in turn lock together the MFWD input and output shafts at the clutch. When you turn it off, oil flows to a piston, which compresses the springs and releases the clutch. You could have friction material coming off the disks, which is allowing them to slip. I stronly recommend running JD Hy-Gard above all other trans/hyd oils. CO-OP oil in particular doesn't seem to agree with the adhesives JD uses on the disks.
MSM
10-15-2005 10:52:09
Yes there are clutch plates for the 4wd.If you did slip it any to speak of the plates could have become warped and you may find you now have full time 4wd. From your description the tractor is WAY over ballasted,all you are doing is wasting fuel,doing damage to the driveline due to over stressing components,won't be long til the front planetaries go south.You need some slippage,lose some weight,take the loader off for one and probably lose some of the water in the front tires. If it still won't pull it wait for some rain,or go get a 4955 before you kill the 44.
TIMAR
10-15-2005 17:31:37
 Re: 4455 mfwd G-MAN???? in reply to MSM, 10-15-2005 10:52:09
Kinda the conclusion I have come to also
