injector's for model R
johnson city bo
10-14-2005 17:09:50
I have a tractor that I pull with and I am haveing power problem"s with. I have a set of Bendix 125"s ready to put in. The one"s I took out are not a macthing a pair. One is a American Bosch and the other is a Bendix Scintilla .Are the Bendix 125"s going to help?
Gpower
10-15-2005 12:43:09
 Re: injector's for model R in reply to johnson city boy, 10-14-2005 17:09:50
The 125 is just the number of the injector housing. Means nothing. All of them pretty much say 125, wether it is on a 70, 730, 830 etc. You should have your pumps and injectors tested and calibrated to see how they are working. If they are stock pistons, you are limited on what you can gain for hp without changing the engine setup. If you need any other info just drop me a line, I"ll try to help. I can test injectors and pumps, as well as give you ideas on engine setups.
