3010 Hydraulic Pump Help!!
Charles Beavers
10-14-2005 16:56:30
Hi Everyone,
My 1961 JD 3010 hydraulic pump drive shaft coupling chatters when reving the engine. I recently installed a newer used drive shaft coupling and it did seem quieter for a while. Now it wants to chatter like before.
If the spline shaft on the hydraulic pump is worn could that be causing the splines on the coupling to wear very fast? Is there a newer style coupling that is not prone to this chatter?
Anyone have a solution to this problem without tearing out the hydraulic pump and replacing the shaft???
Thanks in advance...Charles
Glen Anderson
10-15-2005 13:44:23
 Re: 3010 Hydraulic Pump Help!! in reply to Charles Beaverson, 10-14-2005 16:56:30
Our 4020 had the same problem a while ago. I tried getting the coupler to clamp the shaft tighter by grinding some material from the slots as lonzo suggests but it only lasted temporarily. I ended up replacing the coupler with a new one and chatter was gone for good. If you remove the two-peice clamp from the pump/engine drive and find and movement on the coupler on the pump even after both bolts are tight then your used coulper might not be in that great of shape, also if the splines on the pump are sharp enough to shave with that could be part of your problem as well.
Good luck
Glen
Charles Beaverson
10-16-2005 16:13:03
 Re: 3010 Hydraulic Pump Help!! in reply to Glen Anderson, 10-15-2005 13:44:23
Hi Glen,
Thanks for your response. The newer used coupler looked in good shape, however, when the bolts were tight it did have a little movement. That's why I wonder if the pump splines are worn too. I did grind out the grooves on the original coupler and it did get quitet for a little while.
I heard there was an updated modification for this coupler arrangement. I can't remember who told me in order to check it out further.
Where did you buy your new coupler?? Our John Deere dealer wants $140.00 for a new one.
Thanks...Charles
matthies
10-14-2005 19:49:41
Check and see if the support between the engine and pump is cracked. Seen this once and new coupler didn't last long either. Check the mounting bolts for tightness. chris
lonzo
10-14-2005 19:38:18
when you tighten the two 3/8 bolts on the shaft that is under the radator you could of closed the groove so that the hollow shaft can't be squeed any tighter, i cut the grove wider so i can really make the shaft squeez down on the pume shaft i have seen one JD that was out of line and would eat coupler bushing fast, look real close and see what you find
