Ok. The dimension I think you need is that taken at the bottom of the piston skirt. It looks to me, based on the w-i-d-e tolerance zone given in my book for the top of skirt measurement (90* to pin 5.9998 to 6.1108 and 6.1086 to 6.1096 parallel to pin), that the top of skirt dimension was meant to be just a check of the relief at that point due to the cam ground shape (meaning small enough to not rub the bore). The dimension I have for the bottom of the skirt seems to better match to what they intended to get across with reference to the clearances. That dimension is given as 6.1153/6.1163 (// to pin) and 6.1165/6.1175 (90* to pin. Also, there is the difference in these books....I think....which is a dimension for clearance at the bottom of the skirt: (.0083/.0107 //to pin and .0071/.0095 90* to pin)Now if you use those dimensions, and add these new clearances, you'll get a total that is just at the high/low bore size, meaning if you pair a high diameter piston (let's use the parallel direction) of 6.1163 taken from a low limit fresh bore (6.1246) you would have a clearance of plus with a low diameter bore, you get the low cleanance staed of .0083. Now I do not find an answer to the burning question , which is "What constitues a bore requiring reboring?", so I put this take on it. If you have a piston that is as you have, at 6.105 // to pin and 6.118 90* to pin, and if the piston travels halfway up the bore during the stroke (actually 6 /38" sue to the stroke), then you have a bore of 6.128 and 6.129 at the midpoint, and the piston bottom dimensions are now at the mid point of the block during top stroke, then you have a 6.105/6.118 piston sitting in a 6.128 or 9 bore, so you have clearnaces of .02" and .010", which is probably servicable. However, this does not take into account the wear that might be in the pison pin bores, (wrist pin bushings tend to wear, so if you do nothing else, you'll want to check and probably replace them...it will sure take the slap noise out if it), any ring land wear, and such might encourage you to replace the pistons, and if you buy new pistons, you'll probably rebore. On the bore, I don't think you gave any bore dimensions 90* to the ones you listed. You need those to determine the lowest spot, out of round, and then determine total taper. Taper is the real trouble maker, as it causes those rings to contually be in motion, so I don't much at all. You are showing 6.131 down to 6.125, and I feel that's on the border line. But, you have a big decision, because with the cost of new pistons and machining time, you could be looking at $1200 or more. Wish I had better information. Hope this helps. Frank
