2640 hot start problems
triple
10-14-2005 11:42:44
This tractor starts fine initially but turns over slowly and refuses to restart when fully warmed up. The starter has been replaced at least a couple times. Jump starting causes the engine to spin much faster and it lights right up. The ground cable ran to the batteries seems small (8 gauge at best) while the positive is at least a #4.
I performed a forum search and made note of such things as: poorly rebuilt starters, insufficient fuel delivery only when the components are hot, a large one battery set-up, turning the wheels while cranking the motor, and a manually operated valve to cut out the hydraulic pump while starting.
I haven't tried increasing the size of the ground lead or any of the suggestions I found during the forum search. First I would like to find out if the John Deere 2640 has an "unloader valve" that is supposed to keep the hydraulic pump from trying to build pressure while starting. It is my understanding that my 1855 Oliver has such a mechanism so that the starter doesn't have the added drag of pressurizing hydraulic fluid. However simply cranking the starter without the engine running can actuate the front-end loader on this 2640. Is this normal?
lonzol
10-14-2005 19:50:28
 Re: 2640 hot start problems in reply to triple, 10-14-2005 11:42:44
the ground cables on your tractor is bolted to the batter box from the fatory, i change them to bigger cables and then ground them to the clutch houseing or engin block and that cures things for me,carnk the engin 20 seconds and then feal for hot spots at the battery and lug ends of your cable, that is one way of finding where your problems are good luck
triple
10-15-2005 12:28:24
 Re: 2640 hot start problems in reply to lonzol, 10-14-2005 19:50:28
The ground lead will definitely be enlarged. However, I really want to understand the deal with the hydraulics. Can anyone enlighten me?
JimKS
10-15-2005 20:56:46
 Re: 2640 hot start problems in reply to triple, 10-15-2005 12:28:24
Some of those utility tractors have an electric solenoid mounted on the side of the pump- I think the right side. The solenoid is wired so that it"s energized when the engine is cranked, unloading the hydraulics. If you can move the loader while cranking the engine, then the pump is pumping. Either you don"t have this valve and solenoid (there"s a kit you can buy), or it isn"t working.
