520 transmission lube
Dave_mn1
10-14-2005 08:52:13
Our JD 520 tractor has a leak at the axle on the right side and gear lube is slowly leaking out. How do I know how much lube to poor back in? I don't know how to tell what is the proper level. Do I just fill it up to the cap or is there another way to tell if there is enough? I don't want to run it low and do damage to the gears.
Dave
Mike M
10-14-2005 10:01:55
 Re: 520 transmission lube in reply to Dave_mn1, 10-14-2005 08:52:13
Before you fill it up to the top and really have a mess I'll stop you because the manuals may take weeks to get there. On the left hand side of the trans. case about 1/3 the way up I think you will find a bolt with an aluminum washer under the head (9/16 wrench maybe ?)this is the oil level the case may even have those words cast into it. It's been awhile since I've done one but I think it is there. It may allready be overfilled from things like water in oil,or engine oil leaking into tranny,or just plain being overfilled ?
Dave_mn1
10-14-2005 22:53:35
 Re: 520 transmission lube in reply to Mike M, 10-14-2005 10:01:55
Thanks for the prompt reply. I thought there may be some type of plug to check but I wasn't sure where it was. Our owners manual has been lost and it's a little hard to find one. We have a manual for a similiar JD model,(50?) but it doesn't show how to check the level. It only lists the total capacity. I'll take a look for the bolt on my next trip back to the farm.
Thanks again.
Dave
ChuckW
10-14-2005 08:57:30
Ever consider an owner's manual for instructions?
