4010 brake problems
PUTTER
10-14-2005 07:29:23
I have a 4010 gas tractor. The brakes have locked up on. When i start it up it builds up pressure on the right brake peddle. I,m going to start by tearing into the brake valve. Can anyone tell me where i can get the rebuild kit for this valve including the rubber boots that keep out the rain and dirt. I have no JD dealers close by so would like to order the kit off the net. Couldn't get anywhere at the JD site. Thanks for any help! PUTTER
matthies
10-14-2005 10:27:55
 Re: 4010 brake problems in reply to PUTTER, 10-14-2005 07:29:23
If I remember right, the kit is only the seals/orings. you'll need some balls and misc. hardware also. Since yours is building pressure you might want to hook it to an air supply.(Overhaul first then hook air to it) I once had to weld one of the valve balls to a rod and lap the sealing service seat to get the leak stopped. chris
PUTTER
10-16-2005 09:25:26
 Re: 4010 brake problems in reply to matthies, 10-14-2005 10:27:55
Thanks Matthies for the prompt follow-up. I haven't got the valve taken off the tractor yet but when I get it apart and start the rebuild I will post questions on how to test it before I put it back on. Thanks again PUTTER
Bob
10-14-2005 07:50:46
I doubt you'll find the kit anywhere except at a Deere dealer.
Kit is # AR31946, @ about $20.00.
Boots don't appear to be included in the kit. They are # RE244537, @ about $21.00 EACH.
Use the locator, find a dealer and call them, put the parts on a CC, and have them mail the parts to you.
PUTTER
10-16-2005 09:20:40
 Re: 4010 brake problems in reply to Bob, 10-14-2005 07:50:46
Thanks Bob, I used your link and got registered and the parts are on the way. I'll probably be back on here once I get to tearing into the problem. Thanks again, PUTTER
