500A backhoe
sphargy42
10-14-2005 05:17:47
We have a 500a backhoe we are trying to figure the info on . year built and so on . On the tag serial# 000310 .type -E0097 , engine number is R40850 . powershift tranny . 4cylinder diesel engine. any help is greatly appreciated .
jdemaris
10-14-2005 05:57:56
 Re: 500A backhoe in reply to sphargy42, 10-14-2005 05:17:47
500 Deere is built on the 3020 Ag. tractor platform, so it probably first came out in 1963.
sphargy42
10-15-2005 18:17:14
 Re: 500A backhoe in reply to jdemaris, 10-14-2005 05:57:56
Thanks Jd. Can you tell me if this serial # is good 000310 ? also what does the # E0097 tell you on the tag. engine # R40850 .all help is appreciated . these are hard to find info on it seems .
jdemaris
10-16-2005 05:54:27
 Re: 500A backhoe in reply to sphargy42, 10-15-2005 18:17:14
Your's is an early style 3020 type block and parts are easy to get. Early style 3020 blocks of 270 cubic inches using the same parts are :R26160, R32020, R40850, R46385. The block number you have is found in the following: Power Units w/4270 Eng.; Model 3020.
Wheel Tractors w/4270 Eng.; Models JD500, JD500A, JD500B industrial tractors Includes blocks marked R26160, R32020, R40850, R46385. Serial Numbers up to 280,000. The later 270 c.i. blocks that are slightly different have the following numbers: R46350, R46430, R40620, R40700, R40910,R45950, R47520, R48430, R50610, R72127.
