Hard Starting 37B
jdman(MO)
10-13-2005 19:04:10
I have a 37 B that is almost impossible to hand start. It has a nice blue spark, been thru the carb 2 times, has copper wires, valve clearance is o.k. really good compression. Unlike my 38 A you can crank it over several times with full choke and the plugs are still not wet. Once started it runs good idles good and pulls good. What am I missing. There is a random spit back thru the carb. Russ
buckeye al
10-19-2005 15:07:15
 Re: Hard Starting 37B in reply to jdman(MO), 10-13-2005 19:04:10
Did maybe your carb's choke plate have a large open oblong hole in it? We have an H that did exactly as you describe for years. Dad dreaded trying to start it in the winter. Not until we junked another parts tractor H that we'd purchased for the tires did we realize that the choke plate in ours was missing the spring loaded flap valve that was SUPPOSED to cover the hole from the rear side when the choke is closed. I made a copy of the piece something like 35 years ago because someone else wanted this old carb. The H has started very nicely ever since with that home made piece. Without that part, it never would choke hard enough (unless you pulled it) to get a good slug of fuel and actually start. Just farts, pops & hiccups. Make sure you're not missing a part.
Good luck.
John T
10-13-2005 19:58:55
jdman, my 38 B acts that way at times, but especially if a crowd gathers to watch me start it. When you say a good blue spark, I guess you mean the hand cranking spark is that good also??? Otherwise, I would question the mag spring n trip impulse assembly if she pull started the first foot or so.
Where are you running your start timing??? I like mine to snap right at TDC but not any before to avoid kick back. However, it dont take too much slow start timing (fires too late after TDC) to make her harder to start.
Have you checked for vacuum leaks at the carb or its throttle shaft bushings or the manifold????? ? As you know, that leans the mixture making her harder to start.
Mine likes a lot of throttle and full choke for about two compression pull overs, then I open it a lil to to around 3/4 to 7/8 choke n she starts.
Do you shut her down by turning off the gas n letting her die from fuel starvation, then leave her set with the throttle wide open??? That seems to help.
I think a choke butterfly plate and a throttle plate that is nice n concentric n fits well to the bore helps also. When I rebuilt my carb and replaced the throttle shaft bushings (sure yours are okay and dont suck air???) I learned the inner bushing needs to be pressed as deep down in the carbs throat as possible just to avoid hitting the butterfly. Are your throttle shaft bushings pressed deep down into the bore????
Im not sure on that carb spitting, I guess the valves are okay and you said the lash was okay so ???? but it still makes a body wonder about the intake valves???
There may be more but its getting late n Im tired. Good luck n let us know what you find.
John T
jdman(MO)
10-14-2005 13:47:42
 Re: Hard Starting 37B in reply to John T, 10-13-2005 19:58:55
Thanks for your help. I found the rotor to have about 8 degrees of slop, so put a new one on checked and set timing for TDC spun if over and got a loud backfire. I figured I had the mag on 180 out so switched the wires and spun it and was rewarded with another loud backfire. I did have to change the lag angle other wise it would impulse before the mark. From some of yur other posts it looks like the lag mark should be 2and 1/2 to the left of center. to get this mag to impulse within the range of the bolt slots I had to set it about all the way to the left. I know this cannot be right. Any ideas??Russ
John T
10-14-2005 14:09:36
 Re: Hard Starting 37B in reply to jdman(MO), 10-14-2005 13:47:42
I wonder if your governor shaft is in correct time with the camshaft??? If the flywheels on the correct crank spline and the cam is timed proper to the crankshaft, the governor gear is in correct time IFFFFF FF when the flywheels Left Hand Impulse timing mark is at 3 o closk the female slot in the governor shaft where mag mates into OUGHT TO BE FLAT HORIZONTAL FORE N AFT. If not that affects the mag timing so I would check to be sure the governor is in time before proceeding.
The rear adjustment affects the lag angle and IFFFFF it has a 25 degree coupler and theres no wear in the coupler or trip dogs, straight up represents 12 1/2 advance and each mark is another 5 degrees, so 2 1/2 left is arund 25 BTDC. HOWEVER as Duane Larson always points out, wear affects all that and a timing light is only way to tell for sure.
I set the initial start timing by loosenign the mags mount bolts and turn it CW to retard or CCW to advance so it snaps just as LHI passes the 3 o clock flat mark.
Gotta run I will check back later
PS the top n bototm plug wire swap only works for direct drive mags like Wico C and X. If its a reduction gear drive mag they gotta be correct and onkly one way works NOT 180 out.
John T
jdman(MO)
10-14-2005 15:37:43
 Re: Hard Starting 37B in reply to John T, 10-14-2005 14:09:36
With the flywheel on the mark, the gov. shaft is horizontal, but if you install the mag, and even all the way retarded, it impulses about 1 inch before the mark. I am beginning to wonder if the flywheel is one notch off. I know nothing about the tractor history as my neighbor brought it up because of hard starting. It is a type C wico and the spring is not broke. Russ
John T
10-14-2005 18:26:23
 Re: Hard Starting 37B in reply to jdman(MO), 10-14-2005 15:37:43
But if the flywheel were off one spline and the clutch drive disk wasnt also off a spline and in the correct direction, IT WOULD VIBRATE PRETTY BAD.
To see if the flywheels off, remove the left cylinders plug and use a piece of wire etc to see if indeed the left piston is at TDC when the flywheels LHI is at 3 o clock. If so, its correct !!!! I doubt thats the problem !!!!!
Since you verified the governor is in time with the flywheel at least, Im thinking its more a mag problem for now. Play with the mag in the rear and adjust the lag angle setting every which way but loose and see if you cant get it to where you can then get the start snap to happen at TDC. For sure, when she snaps is when she fires, but being an inch off aint ever gonna work.
Lemme know
John T
Wheres Duane and Glen when I need them lol Im pretty good at the mags electrical stuff but you start getting too deep into the pure mechanical portions and "Im out to lunch"
jdman(MO)
10-14-2005 20:58:00
 Re: Hard Starting 37B in reply to John T, 10-14-2005 18:26:23
Well I adjusted the lag to a tad over 3 marks and now it fires at the mark fully retarded. Popped a few times but never started, wore me out cranking. I was sure the new rotor would fix the problem, but it seems to have made it worse. My friend with only one arm starts his with 3 or 4 turns. Life is not fair. The piston is indeed at tdc when the flywheel is at 3 oclock. Russ
old
10-13-2005 19:52:01
Does the impulse work right?? Is the timing right?? MY 1935 B with the rings from the factory ya 70 year old rings still starts on 5-7 turns. Souns like a small thing is kicking you
