1950 A leaking oil and crankcase vapor
eli
10-12-2005 17:52:59
Need advice on what to start fixing to prevent some oil and a lot of crankcase vapor from coming out around clutch pulley. I noticed it at night in the lights when the tractor got warmed up. My serial number is 658891 and the moter is not wore out. I'm not sure if the problem is with ventelator pump system, or if it lies behind the belt pulley. Any advice or comments appreicated. Thank you,Eli
Walt in Jaxn Tn.
10-12-2005 19:28:42
 Re: 1950 A leaking oil and crankcase vapor in reply to eli, 10-12-2005 17:52:59
Not sure how much "blow by" is normal but what you're looking at is vapor that got past the compresson and oil rings. Even before ventelator pumps, the vapor (blow by) was taken out the vent pipe forward of the governor housing to the front of the carburetor by negative atmosphere present (suction, vacume) there. My 46 "A" has no noticeable blow by after warming up, it dosen't have a ventelator pump. Can you check the inlet pipe going to that pump while the engine is running to see if it has suction? If it does, then I'd think about an easy way to check those piston rings. (my 2 cents) --Walt--
Eli
10-13-2005 18:10:38
 Re: 1950 A leaking oil and crankcase vapor in reply to Walt in Jaxn Tn., 10-12-2005 19:28:42
Thanks Walt. I do have good suction. I investigated this further and checked the blow bye return tube from valve cover. It was clear, but the hole in valve cover was pluged solid. I need to get it out and finish mowing to see if that was it. I wounder if that could have been causing my oil leak also. Thank You Eli
